Ricoh MP2550
  • GeorgeBest
    • Jul 2009
    • 526
    Ricoh MP2550
    Got a returning problem in this machine !
    Paper is feeding from drawer 1 an mostley it runs oke.
    But somethimes it is "folding" in the middle op the paper, no jam.
    changed the heater unit twice !
    It can run for hundred op pages oke and than suddenly the folding!
    someone a clue here?
    No such problem on cass2, which has headed paper, but runs not that often.
    Blanco paper is Ricoh paper, should be ok
    Thanks in advance
  • copyaction
    • Oct 2007
    • 991
    Re: Ricoh MP2550
    I would start with the registration clutch
    • Robertgst
      • Jul 2015
      • 29
      Re: Ricoh MP2550
      It folds in the middle? Does it leave a crease down the middle of the paper or it creases the very top of the page? As if it is hitting something coming out of the tray?
      Also as someone thats new could you explain what types of issues a worn registration clutch could cause?
      • tufbnme
        • 493
        Re: Ricoh MP2550
        Ditto on the registration clutch
        • bob marley
          • Jan 2012
          • 1339
          Re: Ricoh MP2550
          think u need to replace the registration clutch
          Live for yourself and you will live in vain. Live for others, and you will live again
          • GeorgeBest
            • Jul 2009
            • 526
            Re: Ricoh MP2550
            It folds in the middle yes, again no paper jams . . .
            From tray1 and tray3.
            • Zaxxon
              • 608
              Re: Ricoh MP2550
              Gets my vote too
              Please start you post with brand, model, problem.
                • 37494
                Re: Ricoh MP2550
                I had this once. Every tenth copy from tray 1 had a z-fold in it. I noticed that the folded sheets were 8 1/2 X 11 without undoing the fold. I checked the paper in the drawer and found that the fold had occurred before the paper had been cut to size.
                • GeorgeBest
                  • Jul 2009
                  • 526
                  Re: Ricoh MP2550
                  Its more a wrinkle in the middle and at leading side . . .
                  • nkot^1
                    • Sep 2013
                    • 17
