Ricoh mp c6000 problem
  • tolede
    • Jun 2025
    The paper stops in the registration area. It's clear that it's not activating. I have cleaned the sensors that I could find, I don't know this model at all. Any help would be appreciated. Thank you
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh mp c6000 problem
    Is the B4 guide broken? What jam code is it giving you?
    Hit it.
    • Timmytronic
      • Oct 2010
      • 249
      Hi. Does it stop before the sensor or as it's coming out through the mylair? If before it's not the sensor or if after it probably is but that sensor gets mega dusty and if I go to the machine I always give it a blow...and the sensor :0). Use a damp finger tho or cloth as this will stop any static and causing dust to be attracted to it. Check sensor connections also as they can get caught up. One other thing is the old gag. Check to see if there is a piece of paper stuck at the back of the machine.
      Thanks.
      • NeoMatrix
        Senior Tech.
        • 3514
        If it jambs on single copy only, then it may be a dirty rego sensor.....
        Post the first two pages of the SMC report to the forum.
          • 37375
          The jam code gives us a lot more information about the jam than anything you can describe without it.
          • tolede
            I discovered an additional sensor I hadn't found before. I cleaned it and all is well. Thank you all for your help!
