SAMSUNG SCX 4521F
  • karlmweru2020
    • May 2016
    • 30
    SAMSUNG SCX 4521F
    Hello everyone.
    This machine Samsung SCX 4521F displayed the message "Change Cartridge J."
    I took out the ink cartridge, I cleaned, and I put it in it place, the message disappeared but somehow after a few minutes, the machine began to display the message "Warming up, please wait" and remained blocked on this message.
    I do not know what can be the solution to this problem, which is why I come to you with this problem seeking an idea of what may be the solution.
    Thank you for your help...
  • copier parts n.ireland
    • Nov 2016
    • 41
    Re: SAMSUNG SCX 4521F
    remove back cover and check capacitors are not swollen on psu circuit board,this could be the problem.
    • Printmend
      • Aug 2012
      • 67
      Changed the SMPS board (power supply) and it solved same problem.
      Think the problem is C102 & C104 capacitors on the board.
        nice job grave digger thread has been dead for 4 years
        • Printmend
          • Aug 2012
          • 67
          Only glad to be of help to you.
