Samsung part number F/SCX-5935FN
  • blindjoe
    • Feb 2016
    • 16
    [Misc] Samsung part number F/SCX-5935FN
    Need part number for paper feed roller from cassette for Samsung SCX-5935FN. Cannot find the part in parts manual. I ordered what I thought was the roller assembly and it was the feed roller for the bypass. Has anyone else had this problem?
  • daniel411
    Trained Monkey
    • May 2015
    • 24
    Re: Samsung part number F/SCX-5935FN
    Are you referring to the pickup roller?
    JC90-00932A
    • blindjoe
      • Feb 2016
      • 16
      Yes, it picks the paper up from the bottom paper tray. It has a round roller. I would like to order the roller assembly. The number you posted is a different number from what I ordered previously. Is that the number for the roller assembly. Thanks for your time.
      • daniel411
        Trained Monkey
        • May 2015
        • 24
        yes that is the entire part. if the rubber is still course then that may not be your problem or need replaced. i usually feel the courseness of the rubber with my fingers. if it is smooth then time to change.
        • Victor679
          • Apr 2016
          • 26
          Or what I usually do is you can try wiping some oil on the rubber, then leave it for a while and then wiping it off with a cloth. Makes the rubber tacky again.
          • blindjoe
            • Feb 2016
            • 16
            Past the cleaning stage. Now it is time to replace it. Thanks guys for your help. My tech guy at CWS got me another part number. Not the same as the one Daniel gave me. Oh well, we'll see.
