CLX-9201
  • aristos87
    • Oct 2021
    • 12
    #31
    Re: CLX-9201
    Open an empty filezilla and up left in the Host just write ftp.hp.com and then connect... Afterwards navigate /pub/softlib/software13/printers/SS/SL-X4300LX and good luck
    Direct link for SL-X4300LX recovery: https://ftp.hp.com/pub/softlib/softw....J6.00.hds.zip
    • alexanderdia
      • Sep 2015
      • 6
      #32
      Re: CLX-9201
      Cheers thank you
      • Crz
        • Feb 2021
        • 2
        #33
        Re: CLX-9201
        Cheers,
        just to let others know.
        Unix scripts does not exist - nobody can send them. The servicemanual is incorrect/outdated. Its one single .ehd file.
        I tried several files - eg the one from this thread, but it didnt work.
        I found a file on hp ftp which worked. CLX_9301_9201_HDD_RECOVERY_EV11.11.13.36_FS11.01.0 0.00.55.zip
        Idk why the file is in the folder of CLX-9811 ... the filename is clear.
        I used this file plus the info from vigour - thank you!
        ftp://ftp.hp.com/pub/softlib/softwar...SS/CLX-9811CO/
        • TomCat
          • Nov 2022
          • 2
          #34
          Re: CLX-9201
          Originally posted by xordi69
          thanks , i have it and download it. thanks
          I have the same problem, can you send me the HDD image and 2 unix script files by e-mail to cy20201005@gmail.com ? Thanks in advance
          • TomCat
            • Nov 2022
            • 2
            #35
            Re: CLX-9201
            [引用=fornerm;797495]
            你好,
            我有这3个文件,谁能告诉我怎么申请?
            谢谢
            [/引用]
            Can you send me the Samsung CLX-9201 HDD image and 2 unix script files by e-mail to cy20201005@gmail.com ? Thanks in advance
            • crm-informatica.it
              • Dec 2017
              • 13
              #36
              Re: CLX-9201
              ...cut...
              Hello, the Hp's ftp site is not available. (ftp:21 & ftps:22)
              Is there another way to get these files?
              I'm looking for the UI file to try to solve my problem because I have a CLX-9201 that is "Firmware update in progress..."
              Thanks in advance
              Ciao!
                • Dec 2017
                • 13
                #37
                Re: CLX-9201
                If your UI is stuck and the printer is working just take the that UI firmware and put it on a usb after you pressed the * 0 # and let it there, eventually it will update the firmware of the touch panel. The file done the job was V5.16.00.33.00_2015022623.hd and I uploaded it here:
                ...cut...
                Hello, the Google's links work fine, but I don't understand how the .hd UI firmware file works.
                It sems doesn't nothing. What am I doing wrong?
                Ciao!
                • wav
                  • Oct 2021
                  • 285
                  #38
                  Re: CLX-9201
                  hi Are You still after the firmware
                    • Dec 2017
                    • 13
                    #39
                    Re: CLX-9201
                    Hi. I don't understand your question.
                    In true, I got the firmwares (I posted another msg where I said I found the right link to download them), but the UI file didn't accepted by the CLX
                    This means that I'm not able to install a new HD.
                    About the original problem, I solved replacing the Operator Panel. It gone to "another life" during the upgrade to the latest version.
                    Ciao!
                    • camlem
                      • Nov 2022
                      • 1
                      #40
                      Re: CLX-9201
                      Hello,
                      can someone provide the recovery File for CLX-9201.
                      The one in the Google-Link does not work and I get no Access to the HP FTP...
                      Would be great, if you can send Files to: technique@acett.lu
                      Thank you!
                      • Morgano13
                        • Aug 2024
                        • 1
                        #41
                        I have the same problem, can someone send me the 3 files by e-mail to gmdjeufa@gmail.com. Thanks very much
                        • aristos87
                          • Oct 2021
                          • 12
                          #42
                          Re: CLX-9201
                          UI Recovery V5.16.00.33.00_2015022623.hd - Google Drive
                          If you want the hard disc recovery you can find it here:
                          System Recovery CLX_9301_9201_EV11.11.14.09_FS11.01.00.00.71.ehd - Google Drive
                          Recovery for the hard drive I never tried so far as in my case only the display firmware got corrupted. For sure you will find instructions in this forum if you search for clx-9201
                          Guys all the files are uploaded to my gdrive and they work fine... how comes it's not wokring on your side?
                          • alexanderdia
                            • Sep 2015
                            • 6
                            #43
                            Hello,
                            I just seend the file to your email address via wetransfer
                            • KiMa
                              • Oct 2024
                              • 1
                              #44
                              And I have the same problem😆, can someone send me the 2 script files by email kiev.pryde@gmail.com. Thanks a lot
