multixpress 9250nd error si-3110
  • COPYDOCAZ
    • Mar 2015
    • 110
    I went to the service manual first, it says Replace the main board JC92-02429A as the fix for this error code.
    Before I order a main board I checked this site for additional insight. I have read several threads related to this error and the consensus seems to be this is a hard drive error.
    Can anyone tell me if replacing the HDD will fix the problem, and where can I get the firmware to pre install or can I buy a hard drive with it pre loaded.
    Thanks in advance
    Me
  • RICFOWLER
    • Apr 2011
    • 25
    Re: multixpress 9250nd error si-3110
    I can help with firmware and a main board if needed I have a machine here I can take it out of , the error your getting it is highly unlikely the hdd is bad and causing this issue , are you able to clear the code and initialize the machine at all , and when does the error occur
    • RICFOWLER
      • Apr 2011
      • 25
      I apologize too quick to respond , I looked up your error and indeed it suggest replacing hard drive first and firmware , which on these any 2.5 hdd will work you just need the firmware and recovery software to complete the job I can send you the software needed and instructions if needed also
      • COPYDOCAZ
        • Mar 2015
        • 110
        That would be awsome
