Need HDD image files for a SL-X4300LX
    Re: Need HDD image files for a SL-X4300LX
    Originally posted by rashidahmed
    hi ,
    Any one can give me below file for Samsung MFP. CLX 7500
    -unix script files x 2
    -HDD image file x 1
    stop hyjacking threads with a different mode;#
    start your own thread
    • rrrohan
      • Sep 2011
      • 1977
      kinda curious what the Unix script files are because ive never had them and ive recovered atleast 10 samsung drives with just the .ehd file
      • Mitch Barron
        • Mar 2013
        • 180
        • rrrohan
          • Sep 2011
          • 1977
          #19
          are you referring to the fact KM firmware is no longer a single .tar file?
          • Mitch Barron
            • Mar 2013
            • 180
            #20
            No what I am saying is that is only one simple file, and not two as before, the unix and the images files, so now is all combine in one simple file.
            • rrrohan
              • Sep 2011
              • 1977
              #21
              oh you mentioned Konica so wasnt sure
              • Jack79
                • Jul 2014
                • 312
                #22
                I have never seen unix scripts to recover hdd. I always do the job with one file. Maybe as someone mentioned scripts were required for the first version of recovery file.
                • sfel
                  • Nov 2019
                  • 2
                  #23
                  Hello,
                  i am trying to peform a system recovery SL-M4583fx and do not have any files. Can someone help me and tell, which file is the correct one for a recovery on that model and where i can get this file?
                  best regards
                  • Arcadian
                    • Feb 2010
                    • 218
                    #24
                    Originally posted by sfel
                    Hello,
                    best regards
                    I dont think there is a recovery image for the 4583, just put in a working non formatted drive over 160gb, it should boot up, you might have a main board issue or a bad ope panel.
                    • vigour
                      • Aug 2010
                      • 1038
                      #25
                      How does that work.
                      I checked online and 4583 looks exactly like 4580. The specs say 320 gig hard drive like all other Samsungs.
                      I have never been able to get a Samsung to work on a drive smaller than 320 gig
                      Firmware looks similar to 4580
                      Samsung ProXpress SL-M4583 Laser Multifunction Printer series Software and Driver Downloads | HP(R) Customer Support
                      IT seems to be basically the same machine so the hard drived recovery and firmware process should be the same
                      • sfel
                        • Nov 2019
                        • 2
                        #26
                        Thank you for your reply.
                        How do i prepare such a HDD. I tried to put another non-formatted drive in, but it do not boot up. I tried zto use the repair function but the printer chrashes and lead me to the tech mode again.
                        Shouldn't there be any data on the HDD ?
                        I have tried with a 500 GB HDD and the same HDD (320) which was in before after i have cleaned it using diskpart.
                        • vigour
                          • Aug 2010
                          • 1038
                          #27
                          YouTube
                          It only works with 320 GB drives for me.
                          Sent from my SM-G950U using Tapatalk
                          • Arcadian
                            • Feb 2010
                            • 218
                            #28
                            So Sorry there is a File for the drive, I can send you a link, Send me a PM. Ill forward the link. You need to extract it to a USB drive then do the recovery.
                            also it has to be 320 GB just dont use a toshiba drive.
                            • rrrohan
                              • Sep 2011
                              • 1977
                              #29
                              I've recently used a 500gb ok since finding 320 is hard these days
                              • Arcadian
                                • Feb 2010
                                • 218
                                #30
                                WELL ITS HAS TO BE OVER 320GB so to say
                                with that said, you want the link?
                                i want to try a ssd drive since they are getting cheaper have not tried one yet, but it is interesting.
