Need HDD image files for a SL-X4300LX
  • kosmpryw
    • Mar 2021
    • 16
    #61
    Re: Need HDD image files for a SL-X4300LX
    Originally posted by Arcadian
    send an email ill send you a link theres only one file you need
    Sorry, I don`t know why but I can`t send you my email by PM. Please send files to: ko****w@gmail.com
    • cvcr
      • Feb 2021
      • 2
      #62
      hi ,
      Any one can give me below file for Samsung CLX 9201, by e-mail to adrian@validaricleanrooms.ro? Thanks in advance
      -unix script files x 2
      -HDD image file x 1
      • kosmpryw
        • Mar 2021
        • 16
        #63
        Just want to say again - THANK YOU. You helped me a lot, I appreciate it.
        PS. I`ve made some test on 30x SL-X4300LX printers and it seems that HDDs larger than 320GB also are allowed to be used as long they would be formatted as MBR, not GPT. None of my GPT HDDs works, most of my MBR HDDs works (1x 1TB Seagate, 1x 500GB Samsung, etc.). Also - none of my SSD`s worked, even when I`ve formatted them as MBR so...
        • rrrohan
          • Sep 2011
          • 1977
          #64
          I've never been able to use a SSD in place of a mechanical HDD on any copier
          Sent from my Pixel 4 XL using Tapatalk
          • Crowfeather
            Printer firmware is !&$!
            • Mar 2021
            • 130
            #65
            Originally posted by rrrohan
            Turns out it's just a single file and then firmware update once it's booted up fully
            Interesting that size doesn't need to be 320gb. Good thing because they are getting hard to find.
            I only have recovery for a 7600 are they same?
            • toymal
              #66
              Re: Need HDD image files for a Samsung M5370LX
              Hello,
              I need to know if you still have a link to download the following files to recovery my Samsung M5370LX printer.
              It asks me to have in the USB:
              - Unix script files x 2
              - HDD image file x1
              I would appreciate the link that was not broken.
              Best regards.
              • Arcadian
                • Feb 2010
                • 218
                #67
                Originally posted by toymal
                Hello,
                - HDD image file x1
                Best regards.
                send me an email address
                you dont need the unix files
                just the hds file to recover
                • MattThom2016
                  • Aug 2021
                  • 1
                  #68
                  Hi
                  I am having the same issue with a Samsung X4300LX, in the Engineer Diagnostics the HDD is coming back as failed when testing.
                  I have called through to HP/Samsung support but they have been very un-helpful and would not provide the software to build a new HDD to replace the broken one, does anyone have the software/firmware they can send to me.
                  Thanks for any help.
                  • katabar
                    • Feb 2022
                    • 1
                    #69
                    Re: Need HDD image files for Samsung multixpress C9301
                    DO YOU have a link to download the following files to recovery my Samsung multixpress C9301
                    - HDD image file x1
                    THANK YOU
                    Best regards.
                    • clgunz
                      • Jun 2009
                      • 4
                      #70
                      I also have an m4580fx that is experiencing a drive crash. the companies it guy tried to replace the fuser and in so doing messed up the exit sensor. it experienced some sort of physical damage and would no longer work. very shortly after this the hdd went bad so i was thinking perhaps that the two incidents are related. at any rate i have downloaded the file from the hp ftp site. i tried to use the original file after unzipping it once so it shows a .ehd extenstion and it failed on the original drive and it failed with the same errors indicating a hard drive error (multiple errors). i also extracted it various times thinking that perhaps the file needs to be decompressed more before it is able to be read by the system. none of the attempts worked.
                      my question is twofold. do i need to decompress the file from the original zip file to the .ehd file like i did? i noticed that when you decompress it more it will also end with a .gz extension and that the final compressed extension is a .tar before you begin to see an actual folder structure. Im at a loss. there is also some file in the same ftp site under that same folder that says ui recovery and it is an .img file which i have not tried. lastly im wondering if one of the attempts would have been successful if i actually tried a new drive.
                      can i have someone please help out here?
                      • vultur20
                        • Jul 2022
                        • 1
                        #71
                        Good morning everyone. Does anyone still have hdd files for SL-X4300LX? I am having hard time to find it. I would really appreciate that.
                        Thank You in advance.
                        • ESKI
                          • Sep 2022
                          • 1
                          #72
                          Has anyone found the recovery file for X4300?
                          X4xx0_EVxx.xx.xx.xx_FSxx.xx.xx.xx.xx_HDD.zip
                          The FTP sites don't work, tried to contact HP, but no answer, and really no contact info on them.
                          Just bought a new HDD for the printer, would love it, if someone could help me out on this one
                          • Crowfeather
                            • Mar 2021
                            • 130
                            #73
                            Originally posted by ESKI
                            Try opening the FTP site from IE or Edge. Had it before where half browsers won't load it, but sometimes it will load direct from IE/EDGE or Windows Explorer
                            • elvaginon
                              • Sep 2022
                              • 1
                              #74
                              Originally posted by vigour
                              check your private messages
                              I need recovery files for my printer M4580fx can someone please send me the link to download. my mail ID gil.reyes666@gmail.com
                              • wav
                                • Oct 2021
                                • 285
                                #75
                                are you after this
                                K4xx0_series_EV11.01.12.00_FS14.03.06.21.13.HDD.zi p
                                as i have a very large archive of firmwares.
                                pm me for more info on the file.
