Having trouble with scanning using FTP
Tried two seperate FTP servers
One is a internal software package IT developed and the other is FileZilla Server
They both do the same thing
all PDF's are scanned ok but end up with .lck on the end
"Untitled_15112017_145711.pdf.lck"
if you remove the .lck the file opens perfectly fine
it only does this on FTP. SMB and email work fine
log from FileZilla indicates that its defintley the copier causing this
any ideas?
(000006)15/11/2017 15:00:03 PM - test (192.168.0.63)> STOR Untitled_15112017_145711.pdf.lck(000006)15/11/2017 15:00:03 PM - test (192.168.0.63)> 150 Opening data channel for file upload to server of "/Untitled_15112017_145711.pdf.lck"
(000006)15/11/2017 15:00:03 PM - test (192.168.0.63)> 226 Successfully transferred "/Untitled_15112017_145711.pdf.lck"
(000006)15/11/2017 15:00:03 PM - test (192.168.0.63)> PWD
(000006)15/11/2017 15:00:03 PM - test (192.168.0.63)> 257 "/" is current directory.
(000006)15/11/2017 15:00:03 PM - test (192.168.0.63)> RNFR /Untitled_15112017_145711.pdf.lck
(000006)15/11/2017 15:00:03 PM - test (192.168.0.63)> 550 Permission denied
(000006)15/11/2017 15:00:03 PM - test (192.168.0.63)> QUIT
(000006)15/11/2017 15:00:03 PM - test (192.168.0.63)> 221 Goodbye
(000006)15/11/2017 15:00:03 PM - test (192.168.0.63)> disconnected.
