Samsung SL-M4080FX
  • comaiel
    • Oct 2020
    • 18
    Samsung SL-M4080FX
    Hi does anyone have files to restore hard drive?
    Re: Samsung SL-M4080FX
    what happened ?
    • comaiel
      • Oct 2020
      • 18
      what happened ?
      • comaiel
        • Oct 2020
        • 18
        what happened ?
        I tried to restore hard disk from the image file through the pendrive but it crashes at 94%. I tried to change hard disk and it always freezes at 94%
        • vigour
          • Aug 2010
          • 1038
          Do you have another 4080 which you can use to setup the new drive.
          I think I saw that happen once on another model but I do not remember why
          • comaiel
            • Oct 2020
            • 18
            Hi, thanks for the files, unfortunately even with its original hard drive, it reaches 94% and crashes.
            As you said, it would take another drive to try and fix the problem. It is strange, however, that no one in the forum has had a similar problem ...................
