Samsung SF 560R ?
  • vstar
    • Aug 2007
    • 176
    Samsung SF 560R ?
    Customer called and there fax is printing garbage (page after page).
    This is an incoming fax, I have looked in the service and user manuals but I can't find or I am not seeing
    how to delete this fax. Is it as simple as turning off and unplugging for a little, or is it something else?
    If anyone has an idea I would sure appreciate any help.
    Cameron
  • dickierock
    • 252
    Re: Samsung SF 560R ?
    Hi,we've had a few of these models and a few other Samsung faxes and never had any issues like this.
    I have however had something similar on a phillips fax that required a full reset in service mode.
    I'm sure if you fully disconnect the power for a couple of minutes it will reset back to normal.In the unlikely event it doesn't you may need to look at the service manual for clearing/resetting the memory.
    Good luck!
    • vstar
      • Aug 2007
      • 176
      Thanks dickierock, I will try and hope for the best.Thanks
      Cameron
      • oldrn
        • 166
        Stop/Clear button? I believe that works on outgoing, might do it on incoming
