Samsung ML-4551ND Error Code
  • fotocom
    • Nov 2008
    • 96
    Hi all,
    I am trying to get to the bottom of a error code on a Samsung ML-4551ND.
    On switch on the machine briefley goes into system initializing mode then errors
    'NICBridge_IF_Ope
    2983 ROOT
    Internal Error
    Power On/OFF'
    Powering on/off does not change the error, swapped out the NIC board, no change.
    Any help greatley appreciated or even someone who might point me in
    the direction of a service manual.
    I dont normally work on Samsungs.
    Thanks.
  • fotocom
    • Nov 2008
    • 96
    Re: Samsung ML-4551ND Error Code
    As an update, I managed to download a manual.
    The error code seems to be a power supply unit.
    Hopefully that should fix it.
