Samsung SCX-6555NX - (139) 'GVUI_MAIN' has been terminated. (042)
  • michaelharrison1984
    • Nov 2012
    • 3
    [Error Code] Samsung SCX-6555NX - (139) 'GVUI_MAIN' has been terminated. (042)
    Hi, I had a SCX-6555NX showing 'System Recovery' screen so performed system recovery via the XOA slot. After the machine came back to life I go this message:
    This message appears after about 30 seconds of switching the machine on. If you are quick enough you can produce a copy which is perfect so I am pretty certain the fault is software/board related.
    Anyone else seen this before???
    Cheers
    Michael
  • simonchin
    • May 2015
    • 22
    Re: Samsung SCX-6555NX - (139) 'GVUI_MAIN' has been terminated. (042)
    [ATTACH=CONFIG]29581[/ATTACH]
    Cheers
    Michael
    My scx-6545nx has the same issue as yours and I put up on forum last month still got no help but one day I tried to switch SD Card around (under touch screen panel) with another scx-6545nx unit and it work for me
    so if someone out there can help us how to work with that SD Card so next time we dont have to switch around from one to another.
    I hope it can help you and good luck Michael.
