F1-09 on a MXM550N
  • Davidc901
    F1-09 on a MXM550N
    Hello. I've got a MXM550N with an AR-F15 finisher. It's throwing intermittent F1-09 errors. The manual says it's a load capacity sensor in the finisher, but when I check the finisher manual, there's no such sensor listed. Also, the machine usually runs fine, but intermittently throws this code, so when I check the sensors in Sim 3-2, everything checks out ok.
    Another post on here said that there's a service bulletin on it. Can you please give me the service bulletin or let me know what the fix is?
  • mttech
    • Mar 2014
    • 127
    Re: F1-09 on a MXM550N
    This code is related to the height sensor, which is called PS1. See pages 2-40 and 7-10 in the manual. There is also an adjustment on 7-10. Once you find it, it not to bad to get to.
