MXEB13 install on mx2615
  • foudl
    • Mar 2010
    • 138
    Is there a firmware to install the mxeb13 on mx 2615, in UK it says that it needs the wifi driver software ,and if so where can it be downloaded
  • drowranger
    • Jul 2015
    • 122
    Re: MXEB13 install on mx2615
    If the firmware is the latest on the machine it should be ok because this model's firmware supports EB13 from 1st lot of production.
    You have to activate wireless function in sim 26-50 item H ( has to be 1)
    then have to setup wireless connection and configure it from machine op panel or from webpage. good luck !!
    • foudl
      • Mar 2010
      • 138
      Ok, so it works great with iphone but i'm not able to set up an android (it is searching the signal but won't find anything). Does anyone knows if there is a special way to set up the android??
      MX 2615 Version 7.00.G2.00
      Android version 4.2.2 and version 6.0
      • ntbann
        • Jan 2012
        • 623
        I think you have to use the sharpdesk mobile app on android.
