mx-m354n Blank image but drum covered with toner No codes
  • jmcopier
    • Jul 2025
    [Electrical] mx-m354n Blank image but drum covered with toner No codes
    Working on this machine with blank image, no codes Replaced developer and drum unit, same problem
    Any suggestion Not familiar with Sharp machines as I work on Ricoh copiers
    Any help is appreciated, Thanks
  • spanky
    • Sep 2012
    • 468
    Re: mx-m354n Blank image but drum covered with toner No codes
    Transfer roller or HV unit for transfer
    • Dark Helmet
      • May 2009
      • 854
      Check the block behind the drum that has the contact springs for the main charger. If dirty the drum does not charge. Also check the grid is not dirty.
      • michaelc
        Field Tech
        • Mar 2011
        • 590
        Is the laser working?
        It didn't say that I couldn't do it in the manual.
