Sharp Network Scanner Tool
  • Jack79
    • Jul 2014
    • 312
    Hello.
    Network Scanner Tool (NST) is a part of Sharpdesk.
    Is it possible to install NST without Sharpdesk licence?
    Do I need to buy licence to use Sharp MFP printer as a network scanner?
    Can you recommend other scanner software which can be use with Sharps mfp for free like Sharpdesk Mobile which is free for mobile devices like phones?
    Jack
  • Dark Helmet
    • May 2009
    • 853
    Re: Sharp Network Scanner Tool
    Jack check your PM's
    • teklife256
      • Sep 2012
      • 164
      This is a good question. I would definitely appreciate any insight.
      • faxman28
        • 435
        Originally posted by Jack79
        Hello.
        Jack
        need a license for sharpdesk/nst, most newer sharp mfp's come with sharpdesk with one license. NST can be installed without shardesk, just select custom install.
        most Sharp mfps can scan using smb, ftp, and email without a license.
        windows and Mac OSX have a ftp software , the ftp software needs to be "activated" on windows(IIS needs to be setup) and Mac OSX 10.6.8 and below you go into system preferences, file sharing for ftp and OSX 10.7 and above you need to turn it on via a command line in terminal.
        Also a ftp program called FileZilla is very popular.
        • paulostmg
          • Apr 2015
          • 6
          You can download the Network Scanner Tool from this website, www.gfive.net
          -Hover over our services, click download, software and utilities then download Sharpdesk 3.2 . Use this software key 1234-123456-12345678.
          You can also use FileZilla-Server-0-9-53 from Download FileZilla_Server-0_9_53.exe Free - FileZilla Server 0.9.53 Beta install file. You don't need software key for filezilla.
          • paulostmg
            • Apr 2015
            • 6
            You can download Sharpdesk 3.2 from www.gfive.net and use software key 1234-123456-12345678
            • Sam Spade
              • May 2015
              • 7
              I often use the scan to e-mail option using the customers ISP for the server. Seams every time that their computer is worked on the Sharpdesk doesn't work.
              Hello.
              Jack
              • paulostmg
                • Apr 2015
                • 6
                If you have sharp desktop 3.2, use the following key. 1234-123456-12345678. You can install it on more than 10 PC's. You can download sharp desktop 3.2 from www.gfive.net if you don't have one.
