AR168D Check SPF RSPF
  • ben@km
    • Sep 2014
    • 34
    OK I hate to post this one...
    I've tried every trick I know that usualy fix this issue.
    The scanner rod was clean first and finally replaced, steps on bulletin REP1192A done, White and Black Shading (Sim 63-01-02), SPF float level (53-08). Replaced the exposure lamp and we still cannot perform 41-06 without error.
  • ntbann
    • Jan 2012
    • 628
    Re: AR168D Check SPF RSPF
    I have had to replace the scanner motor a few times for this machine. They get week.
    • foudl
      • Mar 2010
      • 138
      Have you try to raise the adf by putting something under the hinge (on the right side) it's quite a long shot but it works for me ...
      • danceswrabbit
        • Dec 2013
        • 65
        Have you tried taking a black sharpie and darkening/widening the lines on the white sheet on the spf?
