MX-4111N admin password reset
  • Jaws
    • Oct 2007
    • 236
    This machine has the data security kit, so you can not use sim 24-30 Used to initialize the administrator password or sim 24-31 Used to initialize the service mode (Web page) password. I have reformatted the hard drive 3 times, and it still wont return it to admin. I dont have one without the data security chips to try and see if that would return it to admin.
    Anybody have any others suggestions
  • PrintToPDF
    • Oct 2015
    • 27
    Re: MX-4111N admin password reset
    Try removing the security kit. Take out the the security board from the PCU. Turn the boot switch SDBOOT to the ON position. Boot up the MFP. Sim 24-31 should be accessible. After changing the password reinsert data security and switch back SDBOOT to OFF position.
    • PrintToPDF
      • Oct 2015
      • 27
      • tr210907
        • Jul 2011
        • 40
        There is a dip switch you must turn on on mfp control board once switched the machine will boot up in sim 24-30....
        • Jaws
          • Oct 2007
          • 236
          Thanks to all that helped. I got that message yesterday. Worked flawlessly.
          • skookumchuck
            • Feb 2012
            • 62
            Is there more than one dip switch on that board? If so, witch one is it?
            • Jaws
              • Oct 2007
              • 236
              Two large ones each by themselves. And one double one next to serial port. Flip the one of the double ones opposite of the serial port.
              • skookumchuck
                • Feb 2012
                • 62
                Thanks!
