MX 2300 Color Copy Quality Error
  • schotschen
    • Nov 2011
    • 33
    Hey Guys! And also Gils if there.
    Here is my Problem:
    We had an MX 2300 in the field.
    The first copy is really Bad.
    If i start the next Copy Job the Print
    is fine.
    I tried Color Callibration and replaces Copy lamp with Controller Board SCNJcnt,
    Scann in PWB and PCU PWB2. Even Firmware Update...
    Nothing works! No Error Codes in the History.
    In Print Jobs ther is no Problem.
    So maybe sombody can Help me out...
    Regards Daniel
  • danceswrabbit
    • Dec 2013
    • 65
    Re: MX 2300 Color Copy Quality Error
    I had something like this only mine was constant till I'd mess with the magenta drum unit. I suspect charger issue in my case but I replaced drum unit. If you can get there for first copy try a copy in single color of magenta and see what it looks like. ( Mine was REAL washed out) . Hope this helps. D.W.R.
    • schotschen
      • Nov 2011
      • 33
      Hey! It was not the Maganta Charger. Problem is still There...
      Replaced all 4 Drum Units for testing. Not sucsess...
      • danceswrabbit
        • Dec 2013
        • 65
        Damn I was hoping it was to be as easy for you as it was for me once I found my culprit. Sorry.
        • schotschen
          • Nov 2011
          • 33
          Re: MX 2300 Color Copy Quality Error E7-01
          Update!
          I had Call from Customer this Morning.
          The Maschine Calls for Service with Eroor E7-01
          This Fits into The Picture.
          So it seems to be an EPROM defekt?!?!?
          The question is now:
          I have an old Maschine with broken Power PWB were
          i can get some Parts. Witch Parts I have to replace now?
          I think when i replace only the EPROM i will get U2 Error Code or
          somephing like this? Right?
          • drowranger
            • Jul 2015
            • 122
            try replacing copy memory first. can be that
            • faxman28
              • 435
              Originally posted by schotschen
              Update!
              E7-01 error
              Trouble content ICU data trouble occurs.
              Section MFP
              Case 1 Cause ICU image transfer trouble
              Check
              and
              remedy
              1) Check the connection state of the MFPcnt PWB
              connector.
              2) Replace the MFPcnt PWB.
              mfp control board needs to be replaced, also don't rule out the mother pwb, it interfaces with scanner, lsu and mfp control board. have had strange issues with this series and the mother pwb ended up being the cause of the problem.
              • schotschen
                • Nov 2011
                • 33
                Thank you all very mutch!
                I will try to replace the hole board with memory next Week.
                Haye a good Time and happy Halloween!
                • Lopakadee
                  • 11
                  Check the IT belt drive gear see if it is cracked ran into an intermittent problem like that the other day went down the same road as you chasing boards
                  • schotschen
                    • Nov 2011
                    • 33
                    Hey Guys!
                    2 Weeks were passt after changing the Control Board. No Service Calls. Silence.... .-)
                    Problem seems to be Fixt.
                    Thanks a Lot!
                    Regards, Daniel.
