MX2314 - please wait
  • Leebs14
    • Feb 2014
    • 457
    I've read the posts on this error posted earlier in this forum but some relate to the 2614 and not the basic 2314. The ram is onboard and not a plug in dimm.
    My machine boots up fine, cleans the transfer belt message comes and goes then it calibrates itself all ok and then says please wait and just sits there. No restart or anything works, can't access system settings or service mode. You can ping it and get a reply but can't open machines webpage.
    Tried emergency firmware update which all went through fine but problem exactly the same?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: MX2314 - please wait
    Unplug the network cable and see if it goes ready.
    • Leebs14
      • Feb 2014
      • 457
      No it doesn't. I unplugged it from the network and then did the firmware but it's exactly the same..
      • ZOOTECH
        • 3375
        Disable Warmup in TC 7-1 to see if it will go ready; also, disable Fusing and DV to see if it will go ready.
        Run TC 25-1 (with toners removed) and check for any levels that might be near over toned or under toned.
        • Leebs14
          • Feb 2014
          • 457
          Thanks for your suggestions but the machine will not allow you into any modes at all to adjust or turn anything on or off. Even starting the machine with the door open it still won't accept p*c* code
          • Leebs14
            • Feb 2014
            • 457
            Update - been back today a replaced the SD card and it worked first time. So must have been corrupted data on the card,
            • michaelc
              Field Tech
              • Mar 2011
              • 590
              It happens on a few sharps. I keep an image of each SD on my laptop for this. Happy you fixed.
              It didn't say that I couldn't do it in the manual.
              • daniele091
                Hi dear,
                you can send me a copy of your sd card?
                I have a printer sharp mx2314, it has blocked the sd and I can not start it.
                I'm waiting.
                Thank you
                • Jyothis
                  • Jun 2022
                  • 1
                  Can you pls share the sd card image for mx2314n
