Sharpdesk on Apple notebook
  • davebtech
    • Apr 2015
    • 176
    Is it possible to set up sharpdesk on Apple notebooks? Thanks Dave.
  • Flash
    • 378
    Re: Sharpdesk on Apple notebook
    I am not sure about notebooks but you can use Sharpdesk Mobile on iPhone and iPad. Hope this helps.
    • bilyahn
      • Dec 2006
      • 1470
      Unfortunately there is not a version of Sharpdesk for Macs you will need to setup scan to network folder which can be a nightmare or scan to email which is a snap. As mentioned above you can see if there is a version of Sharpdesk Mobile in the app store for your device. Have had mixed success with this on older copiers.
      Good luck
      Bil
      • faxman28
        • 435
        sharpdesk mobile needs postscript installed on the mfp also. SHARPDESKMOBILE_DATASHEET.pdf
        the attached pdf is from 01/2013 and mxm260 is not listed.
