Sharp MX M450N
  • Reed
    • Feb 2011
    • 258
    Sharp MX M450N
    Okay. I know this has probably been addressed before, but this machine keeps having toner build-up on the pickoff fingers in the fuser assembly. I recently increased the fuser temp which seems to help. I wondered if anyone else has had this problem and what the fix may be. Ohh and Yes they are using OEM toner. Thanks in advance
  • DINGO
    • 661
    Re: Sharp MX M450N
    Hi
    OEM piker fingers, OEM fusers rollers, and a good densyti toner in developer helps in this issue.
    G.luck
    • seuba
      • Dec 2015
      • 18
      Re: Sharp MX M450N
      I would try replacing dv and re calibrating 25-2 dv stir
