Device Cloning
  • Leebs14
    • Feb 2014
    • 457
    Device Cloning
    Hi all, I have 3 Mx2614's to install into one office all set up the same for user codes and scanning. If I configure one machine fully with all the settings and then export the settings via the webpage, does it copy everything including scan destinations/address book and passwords?
  • drowranger
    • Jul 2015
    • 122
    Re: Device Cloning
    it will but you have to make a device clone (device settings/network data ) & a document filing clone (address book ) from web page. you can also use sim 56 -2 to copy those data.
    Good luck !
    • MattL
      • Apr 2012
      • 97
      Re: Device Cloning
      Remember if cloning codes across via the webpage you need to enable user control before you put the codes back on.
      • nobody-here
        • Mar 2008
        • 237
        Re: Device Cloning
        Hi everybody.
        is it possibile to clone usercode, modify the file with any SW (Excel like) and the reimport to the machine?
        Or is there a way to importo usercodes from an excel file?
        Thank you.
        29 rouge unpair manque.... cous cous....
        • MattL
          • Apr 2012
          • 97
          Re: Device Cloning
          Not as far as I am aware. It would be a nice feature to be able to do this but sadly not.
