MX7040 Screw ID Help!!
  • copytechonline
    • Nov 2011
    • 40
    Hi all one of my techs has taken a 7040 apart and then gone sick, Ive got it back together but I have 2 x strange screws ive never seen before
    and wondered if anyone can ID them or point me to the area they should be as I probably have normal screws where they should be at the moment. TIA
  • sharptech
    • May 2011
    • 40
    Re: MX7040 Screw ID Help!!
    They look like the screws that hold the fuser in...
    T.G.G.
    • harleyrider
      • Oct 2011
      • 348
      yep they hold the fuser in. Not a must but I put them back in so a customer can't remove fuser.
      • copytechonline
        • Nov 2011
        • 40
        Thanks for that!! I had just used normal screws to hold it in ill swap them out.
        • harps05
          Field Service Engineer
          • Mar 2012
          • 111
          A Tech from our place thought they weren't a must also, until a few weeks ago when a client called to report a loud awful noise. You guessed it, without them there was not enough pressure on the fuser pressure gear. With both gears being metal, it was a scary sound. So, as much as a pain in the ass as it is to put them back in, we do.
          • gypsy
            • Apr 2016
            • 6
            [ATTACH=CONFIG]31538[/ATTACH]
            These screws hold the Fuser in place
