Error code H401
+ More Options
Posts
  • quitech
    • 82
    Error code H401
    Hi friends, I have problem with sharp ARM 276 that is flashing H401 Error immediately the power is on.please what can i press to clear the code? your help will be highly appreciate.
  • 1stcavvet
    • Apr 2015
    • 231
    Re: Error code H401
    go into maintenance mode, #,*,Clr,*. I'm pretty sure that's the in, then execute a 14 and a CA, clear all. GOOD LUCK
    • laitang
      • Nov 2012
      • 627
      Re: Error code H401
      H4 01: Sub heater lamp abnormally low temperature detection
      Check the heater lamp blinking with SIM 5-2.
      When the lamp blinks normally:
      Check the thermistor and the harness.
      Check the MCU PWB thermistor input circuit.
      When the lamp does not light:
      Check for disconnection of the heater lamp and thermostat.
      Check the interlock switch.
      Check the power PWB and the MCU PWB lamp control circuit.
      Clear the display of self-diagnostics with SIM 14.
