MX-365N Copies are light
+ More Options
Posts
  • LarryMck
    • Dec 2015
    • 8
    We installed 30 of these new sharps. One of them is making light copies, as in it prints a page fine and then when you make copies it comes out noticeable lighter shades of black. It does this from the doc feed and from the scan glass.
    I cleaned the optics, less then 5000 copies on these machines the optics were perfect. Did the sim 46-24 calibration problem still there.
    I printed a pcl test pattern with Sim 64 then copied the PCL test pattern. The copy came out with streaks in the copy through the shades of grey.
    I went in and adjusted the exposure in sim 46-9 and the text copies came out dark as they should be. I am questioning myself on what the cause of this is and if I still have problems in the machine.
    Again prints fine but has scan issues.
  • foudl
    • Mar 2010
    • 138
    Re: MX-365N Copies are light
    Since you have plenty of machines i would print the 22-6 and compare it with a machine that is working ok, sometimes we get surprises doing so
    • sharphead
      • Aug 2009
      • 285
      Have you done sim 63-03
