I have a MX-FN20 and a MX-FN18 both showing FSHS_S jams while the paper ( mostly ledger) travels down past the saddle staple area and contacts the FSVPPD sensor.
Here it stalls and following sheets jam up behind the upper deflection plate area. Both accounts are heavy pamphlet makers and the problem happens so fast it is hard to determine
the exact issue,but the sheets don't flow smoothly down to the paper positioning plate,they stop ,hesitate ,then jam. The MFP's are MX-6240 and MX-4140 both under 300K.
Any one seen any thing like this?
