Sharp MX 4140 displays just and X and locks up
  • DSallee
    Sharp, Ricoh, Lanier Tech
    • 27
    [Misc] Sharp MX 4140 displays just and X and locks up
    Hey all, I'm working of an MX 4140 that locks up with an x on the display as shown in the attachment. Firmware is up to date, all memory reseated, CF card reseated, SD card replaced and display reset to factory default.
    Any ideas????
    GFI Digital Inc, KC
    SHARP, RICOH, LANIER Tech
  • mansart
    • 852
    Re: Sharp MX 4140 displays just and X and locks up
    Can't say that I have ever seen that......
    If you plug into network, do you have web access?
    If machine pulls IP address via DHCP you can locate using driver install routine, or utility such as Angry IP scanner.
    You mention "Display set to factory default" How was that accomplished?
    Do you get Sharp logo at boot?
    • Tom54
      • Feb 2013
      • 8
      I have seen this and it turned out to be the custom background they were using on the home screen.
      • Tom54
        • Feb 2013
        • 8
        • Silviu
          • Jan 2016
          • 17
          for me that looks like a dp switch for touch calibration on
