MX-402SC
  • Sharptech56
    • Feb 2016
    • 100
    MX-402SC
    This machine says tray 1 out of paper I have changed lift motor main board and all settings but no luck
  • ktucker
    • Apr 2012
    • 23
    Re: MX-402SC
    did you find solution to this issue
    • driving lots of miles
      • Jun 2016
      • 401
      Re: MX-402SC
      check sensors in tray
      • moose55
        • Mar 2017
        • 143
        Re: MX-402SC
        If tray is lifting, then it is sensors in P/F unit.
        The Moose is loose!!
        • mansart
          • 855
          Re: MX-402SC
          Is this during a copy? or print? If print only client is likely sending a document formatted to an odd size. 8.45x10.75 as an example. This typically happens with a PDF and the initial Adobe dialog box has a check box that says something to the effect of "Chose paper size based on document size" Ensure this is de-selected
          • jp74msj55
            • Oct 2014
            • 151
            Re: MX-402SC
            I have had so many of these at one of my large accounts. Paper detect sensors in Paper feed unit 1 are bad. Here is part number and change both sensors as a pair. # VHPGP1A73A+-18. Takes about 15 minutes after you remove right side door assembly.
            • copierdude1114
              • Dec 2015
              • 29
              Re: MX-402SC
              Yup, exactly, pretty ,much any feed issues with those machines point back to that feed unit
