Fuser ?
  • Jack79
    • Jul 2014
    • 312
    Fuser ?
    Hello
    I have removed fuser units from two printers (both MX-3100N) and they are different.
    First picture shows fuser which I always have seen in this machine.
    Second picture shows fuser which I have never seen before. There is an additional "second rail" which is moving and touching pressure roller. Is this a different type of fuser for this model? What is this "metal rail" responsible for?
    Jack
  • PrintToPDF
    • Oct 2015
    • 27
    Re: Fuser ?
    Originally posted by Jack79
    Hello I have removed fuser units from two printers (both MX-3100N) and they are different. First picture shows fuser which I always have seen in this machine. Second picture shows fuser which I have never seen before. There is an additional "second rail" which is moving and touching pressure roller. Is this a different type of fuser for this model? What is this "metal rail" responsible for? Jack [ATTACH=CONFIG]32049[/ATTACH][ATTACH=CONFIG]32050[/ATTACH]
    This is a fuser cleaning roller. It's a consumable Item. MX-310CR
    • tr210907
      • Jul 2011
      • 40
      Re: Fuser ?
      Hello
      Jack
      That is the cleaning roller.. Have seen them become quite chattery out in field. It can easily be removed so I would assume another tech popped that off.. T
      All 310fu1 come with the roller
      • Jack79
        • Jul 2014
        • 312
        Re: Fuser ?
        Yes you are right. I have checked SM.
        • foudl
          • Mar 2010
          • 138
          Re: Fuser ?
          I removed this rod on all my mx-3100n and all of them work perfectly without it ...
