Sharp MX2610 user code
+ More Options
Posts
  • Leebs14
    • Feb 2014
    • 457
    I've set up a MX2610 with user codes for a customer and all works well, they gave asked if there is a way to stop it from showing the usage splash screen when they log in as it stops them from getting on with their work until this screen disappears.
    Hope this makes sense
  • PrintToPDF
    • Oct 2015
    • 27
    Re: Sharp MX2610 user code
    Uncheck the option box "Display Usage Status After login", it's located in User Control > Default Settings.
    • Sharptech56
      • Feb 2016
      • 100
      settings( admin is the password) user control uncheck usage message
      • dwarf
        • Oct 2012
        • 168
        there is a check box somewhere on the web page under system settings...unchecked is off, I think..
        • Ceechtay
          • Sep 2011
          • 157
          When logged in as admin, from either the webpage or via the Setting button at the copier:
          User Control->Default Settings and then remove the check from the box for Display Usage Status after Login and click Submitโ€‹.
          Good luck.
          • Leebs14
            • Feb 2014
            • 457
            Thanks yep sorted it.
