Fax covet sheet editor
  • Leebs14
    • Feb 2014
    • 457
    has anyone had any experience of setting up a template for a fac header sheet using the fax driver?
    i can't seem to find s way to input any details?
  • bilyahn
    • Dec 2006
    • 1467
    Re: Fax covet sheet editor
    It's been years but I doubt they have changed it very much. It's not very user friendly at all. You can use the basic information entries and choose from some really simplistic cover sheets or generate one of your own from the same page that you choose the cover sheets from. Choose edit and make your own cover sheet. After you make the cover sheet you can save it as one of your templates.
    Basic steps are;
    Click print and choose the fax driver
    click print, the fax information window will pop up
    enter your fax number
    click next
    this window is where you enter your cover sheet info if you want or create a new one by clicking edit after choosing the cover sheet bullet
    Good luck.
    Bil
    PS Supposedly you can import cover sheets but I have never had any success with this feature.
