Sharp MX 7001N Color calabration
  • dwarf
    • Oct 2012
    • 168
    Re: Sharp MX 7001N Color calabration
    indeed there are several things wrong with these prints that would be rectified by doing a full PM... try sim 46-24 instead of 46-74...I'll bet that the fuser needs attention as well...
    • faxman28
      • 435
      MFP-SB-083R.pdf
      Originally posted by glenbennett
      dwarf,
      Did you get my last message about maybe its the fuse unit do to the fact the color looks fine and it looks like the rolling of the fuser is causing the waves on the print.. and did u see the PDF i scanned to you it makes scence. also i could not find a sim 44-75 doesn't go that high
      Glen
      follow the attached bulletin , this is a vintage 2007 color . the 2 wave lines may also be 2nd transfer belt unit(have had some recently as the previous techs didn't replace the belt.).on the color square charts the 2 lines are close together that's why I think it could be 2nd transfer belt unit. also on the soccer page at the bottom(if viewing in landscape) that has the web address , the banding and dithering in that color maybe that that color is out of the copiers color gamut. You will know when you do the calibrations following the attached bulletin
