Sharp MX 2615N MX 3115N Screw Lock Question
+ More Options
Posts
  • Ben Around
    • Apr 2012
    • 151
    I had to remove the main drive section on a MX 2615N to correct a discharge LED problem. The tech manual specifies putting screw lock on the mounting screws and bearing collars. Not having any screw lock at the time I did not put any on the mounting screws or bearing collars. Has anyone experienced problems from neglecting to put screw lock on these items.
    I'm wondering if I should go back to the machine with screw lock or if it will be ok until the next service.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Sharp MX 2615N MX 3115N Screw Lock Question
    It should be OK until next service if the screws were torqued correctly.
    • harleyrider
      • Oct 2011
      • 348
      It will be fine. Locktite is for Harleys not copiers. LOL
