Sharp MX-3110N No Network Access
  • buzz
    • Aug 2013
    • 287
    There is no option to input network settings from the panel. After logging in the System Settings with "admin", the network settings do not show on screen.
    Done already:
    Reset to factory defaults from System Settings.
    Re-inserted Aries SD push to click flash on PCB, and re-fitted Aries DIMM chip.
    Updated to latest firmware.
    Tried to recall/restore settings but errors out.
    Also, the nic page is showing the generic 169.... IP address.
    DHCP is showing on, but when plugged into the network, an IP address is not received.
    Any help would be great!
    Thanks.
  • SwisSeV
    • Jan 2016
    • 307
    Re: Sharp MX-3110N No Network Access
    There was old firmware that cause issues similar to the one you are experiencing.
    What version did you update to?
    • buzz
      • Aug 2013
      • 287
      Originally posted by swissev
      there was old firmware that cause issues similar to the one you are experiencing.
      icu main 08.20.a1
      nic 01.05.00
      • SwisSeV
        • Jan 2016
        • 307
        What is the error you are getting?
        Check out this bulletin (TT-062413_1R1)
        • tonasis
          • Oct 2015
          • 10
          Hi all
          We've just come across this on an MX-2610, firmware update did the trick, just so's you know.
