Hello, we are fairly new to sharp machines. I thought I read here somewhere that people are using different feed and sep rollers. It seems like the stock ones dont last very long. I am talking about mostly the MX machines. Also we got one used one here that had urethane type rollers on it. Looking to see if there is something better and what part numbers. Thanks for the help
Using different feed rollers?
Re: Using different feed rollers?
Hello, we are fairly new to sharp machines. I thought I read here somewhere that people are using different feed and sep rollers. It seems like the stock ones dont last very long. I am talking about mostly the MX machines. Also we got one used one here that had urethane type rollers on it. Looking to see if there is something better and what part numbers. Thanks for the help -
I don't see any AR-623RT, I do see AR-620RT...
Is this compatible with sharp mxm950
My issue... machine jamming... I installed... MX-850RT
on lct... it worked good for awhile like a week and then it simply got worse than before... another tech recommended going back to the grey rollers... and the coupling... ncpl-0081fcbz... checking if the rollers NROLR1466FCZ1 in the ar-620rt are a good replacement for the urethane rollers NROLR1682FCZZ in the mx-850rt...Sad To Say I Don't Have a Life
I do this stuff on the weekends tooComment
