Setting up MX-B201D with computer with windows 10 m=system not acknowleding printer
  • axyun
    • Aug 2007
    • 1323
    have MX-B201D which has copy/ print/fax/scan
    Have computer with windows 10/ 64bit
    Did not have disc. Downloaded software from sharpusa. This is what I downloaded:
    windows 64 bit os driver package including pcl_ps_ppd_twain driver with MX-NB11 software for MX-B201D
    Windows software option package including button manager(GDI) software for MX-B201D
    connected computer to usb port
    Should I have connected to Ethernet . I thought that scan option required connection to usb port.
    Your help is very much appreciated. This is for myself I'm my home and not for customer. Frank/ActionPhotocopy
  • walterman
    • 196
    Re: Setting up MX-B201D with computer with windows 10 m=system not acknowleding print
    Scanning has to be done via Ethernet.
    • Dark Helmet
      • May 2009
      • 853
      If you are hooking up with USB you need the GDI drivers.
      Windows 64 bit OS Driver Package Includes: SPLC(GDI), TWAIN Scan (GDI) Driver Without MX-NB11 Software for MXB201D
      If you have the NB11 network expansion you can use the PCL 6 drivers then install sharpdesk to do scanning.
      The GDI drivers should allow you to see the copier as a scanner. IF you enter devices and printers you should be able to Right click on it and do "START SCAN". Thats how it worked on windows 7. Ive never tried on 10.
