Sharp AR-M550U
  • tcypy1961
    • 773
    Sharp AR-M550U
    Can HDD be intermittent; copier was giving an E7-03 yet was usually resettable; eventually removed printer card because of another code either CE-00 or CE-01 can't remember; however after printer card was removed both codes as of now have gone away. Any thoughts or help appreciated.
  • SwisSeV
    • Jan 2016
    • 307
    Re: Sharp AR-M550U
    HDD can be intermittent. With that old dog, there is a good chance the PCU/MFP PWB's are, or are going to, become a problem.
    I got one right now with a E790. It has been sitting in the warehouse for months now, it will probably never be fixed.
    • igi
      • 1507
      Re: Sharp AR-M550U
      hi
      on these machine ce-00 will appear if network cable is not plugged in or faulty,
      you can switch ce-00 off, with soft switch.
