Sharp AL2030 how to put TEXT as defaul t
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Hello This machine is having very light copies in AE mode, the machine has been serviced and all consumables replaced by oems
    nevertheless the quality is bad the 46/01 and 46/02 is no help, (the machine won't accept the new values, the copy output is correct while in progamming mode, but when used as customer the exposition is too low), the only solution for now would be to put the machine in TEXT mode instead of the AE mode, is there anyway to do this?
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
  • Jhonjon
    • Sep 2013
    • 208
    Re: Sharp AL2030 how to put TEXT as defaul t
    I'm not sure if i remember it correctly, men the machine is older than my 10 year old son. Press the auto exposure for a couple of seconds (Try opening the front door and also try the front door close)and adjust the exposure density to darker if you see it blinking. Good luck...
