Sharp machines curling paper
  • Leebs14
    • Feb 2014
    • 457
    [Misc] Sharp machines curling paper
    I look after a number of mx2310, 3111, 2314 machines and a common complaint I am getting is that the paper comes out curly. I've tried turning the paper over and even using better quality paper but it seems using 80gsm standard copier bond paper these machines make it curl on exit.
    Am I missing something?
  • audyplongo
    • May 2016
    • 43
    Re: Sharp machines curling paper
    is it on all types of paper?
    • Leebs14
      • Feb 2014
      • 457
      Just normal white plain copier paper. I've tried 5 different manufacturers and the results are the same
      • SwisSeV
        • Jan 2016
        • 307
        Sounds like paper moisture.
        • Leebs14
          • Feb 2014
          • 457
          I would agree but I've seen this problem at 20+ customer sites with these machines and they all can't be suffering from paper moisture
          • audyplongo
            • May 2016
            • 43
            could be the heat on the fuser temp is a little to high have you tried adjusting the temp or replacing the fuser?
            • Leebs14
              • Feb 2014
              • 457
              I haven't adjusted anything as yet. I'm going to a new mx2314 tomorrow which has about 1000 prints on it and the customer has complained about paper curling out of the exit. I will try lowering the fuser temperature
              • SwisSeV
                • Jan 2016
                • 307
                There is a bulletin about the paper curl and fusing anomalies for some of the machines you are having issues with.
                It has a very helpful graph for the range of adjustments to the fuser.
                MFP-TB-525
                • Jack79
                  • Jul 2014
                  • 312
                  I have seen the same problem on MX-2301/2600/3100 machines here in UK.
                  • sck
                    • Mar 2009
                    • 20
                    we have had this on a few mx2310 and have replaced the Delivery sponges.
                    • Leebs14
                      • Feb 2014
                      • 457
                      Supplied the customer better paper at a lower cost than they were paying and it doesn't curl now
                      • sharphead
                        • Aug 2009
                        • 285
                        The sponges previously mentioned do fix this problem for the most part. Paper can help too. Sometimes it can be fuser related, temperature and if the bearings are getting tired.
                        • boutn
                          • Jun 2016
                          • 540
                          Does anybody know if there are exit sponges for the MX-5112/MX-5141 series?
                          We have a client who has trouble with double sided A3 prints...problem well known with sharp...
                          Looked something like MFP-TB-1202, but nothing to find...
                          • Service@PRT
                            • Oct 2016
                            • 181
                            from what i experienced... mx363n changed web then kwala...paper curl gone for good... ofc you need to do sim with it.
                            Every day of life is a learning process...
                            Just make sure you are open in all aspects of comments.
                            • Jack79
                              • Jul 2014
                              • 312
                              Hi.
                              I have 2610N which does not have these sponges at all. Where can I purchase them?
