ROM Check
  • joelsa12
    • Nov 2008
    • 260
    ROM Check
    So in the past on the older Sharps I was able to go into management mode and check if the three system ROMs matched. I believe that a tech has one switched. I for the life of me can not remember this SIMM. Does anyone out there remember this?
  • Nachoman4life
    • Oct 2007
    • 212
    Re: ROM Check
    Incorrectly inserted, mismatched, or damaged eeproms would give an u2xx error code. Sharp is pretty strict, when it comes to eeproms. If it is the older flash rom cards, as long as the card is the correct size and type, ie 8, 16 or 32mb, and the program rom is correct, should be ok.
    Where the heck is my spring hook?
