MX-M450N Codes with U6-03 After Motor Replacement
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Electrical] MX-M450N Codes with U6-03 After Motor Replacement
    We have a Sharp MX-M450 with an LCC Desk unit and the right tray is not lifting. We replaced the associated lift motor and STILL get a U6-03. Any ideas? Thanks in advance!
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • havokprod
    • Oct 2012
    • 159
    Re: MX-M450N Codes with U6-03 After Motor Replacement
    If no snapped cables or anything dumb like that, I've had bad lift motors blow the pcb on the LCC.
    • spanky
      • Sep 2012
      • 468
      Remove motor from the frame and try running it with a simulation.
      This will tell you if it is receiving the signal to drive and there is a mechanical problem.
      If it does not drive then you may want to replace the PWB.
      • brokey
        • Oct 2011
        • 22
        Did you rest the code with sim 15?
