Sharp AL-2080 drum
  • bcopier2815
    • Oct 2015
    • 42
    Sharp AL-2080 drum
    I am looking for a drum for a Sharp AL-2080, part number AL-200DRU. They are apparently discontinued but I was wondering if there was something compatible or at least a drum i could use to re do their unit. Any help would be appreciated
  • Sam Tofu
    • Dec 2007
    • 130
    Re: Sharp AL-2080 drum
    world of Fax carries parts for these smaller machines and often has drum units/drums that many other distributors don't have.
    their number 800-634-9329
    • travi
      • Jan 2008
      • 129
      We use an AR-152DR and cleaning blade to rebuild them. Be careful not to break the main charge unit. Use simulation to reset drum counter. Katun sells rebuild kits with instructions
      • hellcat
        • Jan 2012
        • 132
        Actually its an AR202DR used to be AR200 but they updated the drums and replaced the numbers.
        Go to Katun or ebay and you should find what you need. You may find the whole drum unit just as cheap as a rebuild blade and drum.
        • travi
          • Jan 2008
          • 129
          Sorry for wrong number for the drum. I mistook the model for the FO-2080.
