Mxm2615 noise (kind of skweek) comes from the fuser ,updates are all done,is there any new fix for that
Mxm2615n fuser noise
Re: Mxm2615n fuser noise
Did you mean mx-2615n?
A bearing noise, is probably the heat roller bearing. A popping or grinding might be the pressure springs, they could be greased where they attach. The web unit can be noisy if it's dirty, I think they have a tech tip to run the cloth over the outside rod to reduce noise in that unit.
The cam unit can wear and make noise too. -
The feed head just after the fuser can be the source of the noise. I just had that issue with a 3610
Sent from my iPhone using TapatalkComment
