Firmware update on a Sharp MX 4101n
  • Utahrob1
    • 38
    [Misc] Firmware update on a Sharp MX 4101n
    Good morning all
    I need to know how to install the firmware from a flash drive. Any help would be awesome!!
    Tnx, Robert
  • SwisSeV
    • Jan 2016
    • 307
    Re: Firmware update on a Sharp MX 4101n
    (1) Firmware update procedure from the USB memory
    The firmware update executes by SIM49-01.
    1) Insert the media or USB memory which stores the firmware
    into the main unit.
    2) Enter the SIM49-01. Press the key of the file to be updated.
    The screen transfers to the update screen.
    * The number of key changes according to the number of the
    sfu file in the media or USB memory inserted.
    * If the media or USB memory was not inserted when entry to
    the SIM49-01 screen, "INSERT A STORAGE FIRMWARE
    STORED ON [OK]" is displayed on the screen. Insert the
    media or USB memory and push the [OK] key to open the
    file. If the media have not been inserted and [OK] key is
    pushed, the next screen does not appear and the screen
    waits the entry. Conversely, if the media or USB memory is
    pulled out on the file list screen, the error is detected by the
    [FILE] key pressing, and the first screen appears.
    3) Current version number and the version number to be updated
    will be shown for each firmware respectively.
    4) Select the key of the firmware to be updated. The key will be
    highlighted. (In this screen, [CONFIG] and [ICU(BOOTM)] are
    selected.) At the same time, [EXECUTE] key appears.
    If firmware's key is not selected, [EXECUTE] is gray out and
    cannot be pressed.
    * Press the selected key again to release the selection.
    * Press [ALL] key to select all items.
    5) Press [EXECUTE] key. โ€œARE YOU SURE? [YES] [NO]โ€
    becomes clear. Press [YES] to start the update of selected
    firemware.
    The progress is displayed on right side of "FIRMWARE
    UPDATE" title by 20 steps.
    At this time, only the progress gauge is displayed on the
    screen, and the version and the firmware selection key are not
    displayed.
    6) If the update is normal completion, following screen is displayed.
    Exit the simulation mode and turn off the power.
    Go to Simulation 22-05 and confirm the firmware has
    upgraded successfully.
    7) If the update is not normal completion, following screen is displayed.
    * When the power supply is turned off due to a black out etc. while
    updating or when the update terminated abnormally, a part of the
    main program stored in HDD may be damaged and may not
    booted normally.
    • Utahrob1
      • 38
      you cant get into sim?
      Hey thanks so much for the quick reply. Is there a way of doing this if
      • ZOOTECH
        Senior member of CRS
        • 3375
        If you can't enter sim mode, you'll have to do the emergency update which will have
        different instructions.
        • SwisSeV
          • Jan 2016
          • 307
          • mttech
            • Mar 2014
            • 127
            You will have to rename your firmware file emupdate_J2.sfu for the emergency update.
            • chatkal1
              • 13
              It can be done using web interface as well. Machine has to be on the network though. Download latest firmware from sharp-idncservice.com, save it in a network shared folder. Login from any PC using browser, type address which is IP address of your machine, enter admin password, look for "Update firmware" link, provide path to the firmware file you downloaded, click Update.
              • Utahrob1
                • 38
                Tnx all. I have the firmware loaded on both machines. You rock!!! One problem though both machines are giving me a U2-60 error. Something to do with the watermark portion of the firmware I am guessing.
                Any ideas for this.
                Thank you again!!
                Rob
                • Utahrob1
                  • 38
                  Ok i just read that i need to rename file to emupdate_12.sfu. I will try that to see if it helps.
                  • mttech
                    • Mar 2014
                    • 127
                    There is a separate file for the watermark firmware. Download that file onto your USB stick, then use sim 49-5 to upload to copier. That should take care of your U2-60 code.
                    • Utahrob1
                      • 38
                      I dont have access to the Sharp site to get the watermark firmware. Is is emailable? or can someone send me a dropbox link? my email is robert8175@gmail
                      Thank you!!
                      • Utahrob1
                        • 38
                        Thanks all for the help. Everything is loaded fine.
                        • 2010mohamed
                          • Oct 2017
                          • 28
                          I dont have access to the Sharp site to get the firmware ? or can someone send me alink to download it ? my email is gawaderaky@gmail
                          i have sharp ar-6020 firmware need
                          Thank you!!
                          • benjamincripe
                            I have a MX 4101n that the HDD stopped functioning in, and I put a new drive in, but I don't have access to the firmware downloads. Would anyone be able to assist me with getting the latest emergency recover firmware for this device? benjamincripe@gmail.com
                              Wow other than another beggar.. this thread hasn't been active for four years! We usually consider this thread to be dead even after 2 years.
