Sharp 6201n Black Developer Problem
  • daniel411
    Trained Monkey
    • May 2015
    • 24
    [Misc] Sharp 6201n Black Developer Problem
    I have been dealing with an issue of a customer on their sharp 6201n. Their black developer is not lasting as long as it should in that I have changed it 3 times in past year. I am no expert with sharp machines at all and I am not sure if the developer unit itself is bad or maybe a sensor. If anyopne has any past similar expereince with this issue please lend a hand in my direction..
    dan
  • techmann
    • May 2016
    • 41
    Re: Sharp 6201n Black Developer Problem
    Have you replaced the DV unit? Where are the consumables at? When you say bad...? Error code, CQ?
    • daniel411
      Trained Monkey
      • May 2015
      • 24
      no i have not replaced the dv unit yet. I was planning to change it but i wanted to see if anyone else had a similar problem. the prints are coming out with white lines down the page. no error codes. CQ? not sure what that is?
      • techmann
        • May 2016
        • 41
        Sorry, Copy quality. So I'm guessing you are seeing a white band on the dv unit magnetic roller? Sounds like you may have a foreign object material in the DV unit, that keeps coming back on you. I would order the whole unit and DV material. (developer)
        • daniel411
          Trained Monkey
          • May 2015
          • 24
          Yeah I am gonna order it today. Thanks for your help I really appreciate it.
          • jp74msj55
            • Oct 2014
            • 146
            I would change Drum and Maintenance kit as well. If drum is shorting out, it will pull developer. I'd lean that way first.
            • chatkal1
              • 13
              And I would replace DV seals as well
