Sharp MX-C311 copies good prints very faded
  • Ingersoll
    • Nov 2008
    • 74
    I don't understand why the copies are really good BUT prints from PCs or prints from USB are very faded. Has anyone seen something like this?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Sharp MX-C311 copies good prints very faded
    I have not seen the symptom, but heard there is a memory chip for copies, and one for printing. I would first clean contacts of memory, and, of course, reseat them.
    • Ingersoll
      • Nov 2008
      • 74
      Sharp Tech Support told me about Technical Tip TT_051915_3 which is for the MX-2615N/2616N/3115N/3116N series but has the same symptoms of copies are fine but prints are faded. Run 67-31 to reset and check with 67-33. Worked for me on a MX-C311.
      • nottoosharp
        • 266
        I've been having the same issue with the 5111n. I wonder if this will help
        • Ingersoll
          • Nov 2008
          • 74
          I've used it twice when nothing else seems to work and it fixed the issues.
          Your experience may vary.
          • nottoosharp
            • 266
            Check sd card. Replace if you can
            • DAKOTADAN
              • Jan 2011
              • 61
              If this is a machine that another tech maybe changed some settings on or the user has changed the exposure settings defaults on then I would do a auto calibration in the system settings,
              on both the copy and print modes. If this don't help then set the machine back to the factory defaults. I am having to do this more often as this series has been in the field for awhile.
              Hope this helps. Dan
              • nottoosharp
                • 266
                My 5111 had all set to zero
                • ZOOTECH
                  • 3375
                  Exposure settings at zero? I believe defaults are at 500; best to start from scratch with a full calibration and adjustments.
