Sharp MX-M365 H5-01 code cannot get into "copy" mode to reset the H5-01 code.
  • Huffy85
    • Jul 2025
    [Error Code] Sharp MX-M365 H5-01 code cannot get into "copy" mode to reset the H5-01 code.
    Sharp MX-M365 H5-01 code cannot get into "copy" mode to reset the H5-01 code. When the tech tried to do th reset he code not get into copy mode which is the first step in resetting. Any help would be appreciated.
    Thanks Brian
  • chatkal1
    • 13
    Re: Sharp MX-M365 H5-01 code cannot get into "copy" mode to reset the H5-01 code.
    Pull out the fuser, check if there is still paper in paper exit section. Check the sensor and its actuator. Reboot the machine, try to get to SIM mode again
