MX6201n Error Code F1-34
  • LtDanDan
    • Jul 2025
    [Error Code] MX6201n Error Code F1-34
    Sharp machine is giving a F1-34 error code every couple of days now whether they are printing or scanning and is preventing them from using the machine. I have read that this is an indication of a Finisher Punch Motor problem but I wanted to confirm because I'm not familiar with Sharp machines and do not have much access to actual manuals and error code lists
  • SwisSeV
    • Jan 2016
    • 307
    Re: MX6201n Error Code F1-34
    F1-34
    Trouble content Punch motor operation abnormality
    Cause: Motor lock, motor RPM abnormality, motor
    overvoltage, finisher control PWB trouble or punch control PWB trouble
    Check and remedy:
    Use SIM3-3 to check the operation of the punch motor (FPNW).
    Replace the finisher punch unit (Replace the punch control PWB.).
    • LtDanDan
      Exactly what I needed, thank you. I just found the service manual for the machine too so that is going to help greatly also
